Had my secondary CAT removed [CLK 500] and passed MOT without a flicker. The main CAT does more than enough 'good stuff' to get through the emissions test....
Sent from my iPad using MBClub UK
AMGeed said:Problem is, the OP appears to be asking if its an MOT pass if the main cats are removed and relying only on the secondary cats.
....Sorry - are you with the 'Comment Police'? Just adding an observation - isn't that allowed?
I was under the impression that if the car passes the emissions tests it is a pass
Lol. I love forums.
No, the regulations changed at the beginning of 2013 I think and now if a car was fitted with CATs when it left the factory, it should still have them (regardless of emissions).
Previously, I only had primaries (secondaries removed) and it passed without issue - even after the new regulations.
However, I am looking to just have secondaries without primaries.
So yes, if just secondaries fitted, is this an MOT failure?
Couldn't all this stress and worry about CATs, secondary CATs and de-CATs be avoided if people just left the damned things alone ?
VOSA are clamping down on this big time, 2 testers had their license suspended around here for passing vehicles that had had decat's. VOSA perch outside the test centers that are associated with performance cars and the either raid whilst on test or wait until just after the test, as they have live info on their laptops from the VOSA terminal in the garage so know if the tester has passed or failed the car.
Couldn't all the stress and worry about global warfare and famines be avoided if people were just nicer, more tolerant, and fairer with each other.
Just saying.
Most definitely.
However, one is probably impossible to achieve whilst the other merely requires you to leave well alone.
This is a bit of a worry - I wonder how long before VOSA will start taking the same stance with DPF's?
