Stratman
New pass/fail categories, tougher on diesels
Extract from the AutoExpress article
Testers are also being instructed to check to see if DPFs have been removed or tampered with, and must refuse to test any car where the “DPF canister has clearly been cut open and re-welded” unless the owner can prove this was done “for legitimate reasons such as filter cleaning.” This last instruction clarifies outgoing MoT rules, which stipulate a car should be rejected only if its DPF is totally missing.
