The rules have changed and they are pretty hot these days. As the rears are on the minimum you might as well replace them.
Part of a bigger bill though. 3 out of the 4 wheels have been kerbed and I was considering refurbing the wheels at the same time as tyre replacement.Bin them off now, today. They are rotten and unsafe. What are you looking at £3/£400 max. get them replaced.
As the big fat tyres are quite noisy. when looking at replacements I was going to look for low db rating & high fuel economy rating.
Any suggestions?
Any suggestions?
Fronts 225 40 ZR18 92YWhat size are they? And how much do you want to spend
SLK is in for MOT in about 1 months time.
All 4 tyres are dated late 2012/early 2013. There is 5mm tread remaining on the fronts & 3mm on the rears.
However, all 4 tyres are perished around the outside of the tread
Will it fail MOT due to this?
The minimum is 1.6mm
OK.
It looks like I'm shopping at Black Circles & Wheel Worx tomorrow.
For ongoing protection of alloy rims, does anyone have experience of AlloyGator or similar?
OK.
Once tyres get below 3mm they loose a significant amount of grip so best to replace at 3mm.The minimum is 1.6mm
