talltimtam
- Apr 16, 2007
Dont know whats up with the car (W211 E320CDI) but I am now getting 24mpg on runs around town. Does the cold weather really impact fuel economy or am I just being unlucky ?
Cold doesn't affect a diesel anything like as much as a petrol due to no requirement for a richer mixture when cold.
Having said that the mpg for my last tank has been slaughtered to 34.6.....
However the fuel becomes more viscous due to the weather being colder, and in my recollection it takes far longer for a diesel car to heat up and therefore run at maximum efficiency.
However the fuel becomes more viscous due to the weather being colder, and in my recollection it takes far longer for a diesel car to heat up and therefore run at maximum efficiency. In my case on the commute to work, about 8-10 miles. My petrol cars never took this long to warm up, usually in 3-4 miles.
But even when stone cold it only requires 10% more fuel maximum as opposed to 400% more like a petrol.
The very fact that it takes so long to heat up shows it is working effciently anyway.
What difference does the viscosity make and how much does it thicken anyway.?
hence I reckon the increased viscosity of the fuel must be an issue.
With modern injection systems, due to the extra density of the fuel as its colder, maybe more is injected. Certainly the air is cooler and therefore more dense, requiring more air to keep the stoikiometric ratio the same.
Diesels don't use stoichiometric fuel mixtures and if injecting more fuel would produce more torque so accellerate.
Stoichiometric fuel mixture is ~15:1 and diesel AFR generally varies between 100:1 maximum and 25:1 minimum.
I can't see the fuel viscosity having any bearing at all and anyway, it's possibly less viscous due to winterising distillates being added.
If viscosity of a given fuel created a performance advantage then veg oil would give much greater output, which it doesn't.
I'd get the E500 gizze. You know the phrase "you'll never be late with a V8".
As estate cars go, a 211 IMHO would tick more boxes as that type of car than an E60. An E500 would be an excellent buy for you and you've still got an M3 anyway.
What I'm trying to say is that the diesel doesn't need to be at optimum temperature to be efficent, it's efficient even when stone cold.
I still don't get why I see a bigger percentage drop with the diesel than the petrol,
