Hi All,
Hoping you can shed some light on my issues as I have codes coming out of my ears and although I can get discounted genuine Mercedes parts the false diagnostic is starting to cost a lot!!
I purchased this W203 2005 M271 C180K Spot Edition for £2700 and after multiple viewings and test drives I fell in love and bought it. Looking back through the receipts the badly made cam gears have already gone and I have around £2000 with of receipts for head skimming, valves, hardened cam gears and all the other bits associated with the damage the failure of these gears cause. After seeing this I presumed the car was through the worst of it.
On the drive home from picking it up (45 miles) the engine warning light came on so took it steady to get it home. On the way home the cluster started showing failure and visit workshop (I don't think the two are linked). When I got home I plugged in my Delphi unit and around 50 codes were on it. I cleared them all as the car was running correctly and took it for a little drive and again the light came on. It was the 'intake cam position intermittent' so I changed what I thought was the position sensor and now I know is the cam adjustment sensors. Reset the codes and drove it again.
The light came back on and the cluster goes wild from lights flashing to dials at zero while driving. I have today changed the cam intake sensor @ £150. Reset the codes and took it for a drive, the light has come on again and the cluster is still going mental. As everything is working correctly I am still driving it as I need it at the moment.
I noticed the other day that the rear footwell was damp and when plugging in the Delphi I am sure I felt a little water while plugging it in. I have checked and the front scuttle was blocked so I have unblocked this and the footwell is drying up nicely. I have reset the codes tonight and need to use it for a 50 mile round trip tomorrow so I will log all the fault codes it brings up on the run tomorrow and update the thread.
In the meantime is this anything you have heard of before or do you know of areas to check? Any help will be muchly appreciated as I love the car and don't want to have to sell it on if it is reasonably fixable.
It's nice to be important but it's more important to be nice! [emoji317]
