My E class is broken :(
A210AMG
England
Hello
Been away for a week in Yorkshire and had a great time, noticed a few times walking back to the car 'water' under the car.
Didn't think too much of it....Car seemed to drive normally and towed the caravan home nicely :) At around 26 - 27 mpg which is great.
However when home it had rained and on reversing the car on the drive noticed drips all down where I had reversed... oil / coolant type patches.
Booked in at local Indy at once.
They orginally had though a seal where a plug is connected to the gearbox but on test driving it and looking at it again its the pipes that connect to the oil cooler have coroded and apparently a right mess underneath :(
Anyway its getting new pipes / filter / ATF change. Its should be great when I get it back as I have noticed you have to press the pedal a lot to get it moving (I just put this down to it being a diesal) but it was the gearbox slipping.
In the mean time I have a CLK200 Kompressor and while it was fun fitting the base station and getting our smallest in and out of it I actually quite like it :)
It goes ok for a small engine, I managed 34 mpg cruising back from garage (18miles A road) and given its an X reg its probably worth around £2500 ?
Will be nice to get back in mine though :)
renault12ts
MB Club Veteran
2005 W215 CL500.
You do have to push the throttle a lot, as you say because it's a diesel. Hope it's not too costly.
OP
OP
A
A210AMG
England
Its pretty good really...
I googled things and you get the worse... I was thinking a lot more.
All in £275 and that includes the ATF done with filters etc.
I need the car in two weeks time as we are off to Europe will be nice having it back and being even smoother :)
