Dave at d:class is your man
Can you replace these with a glass screen or would that hinder the folding?
Yup that's where I'd planned to take it - will be giving them a call tomorrow. Want to ask about retro-fitting heated seats too.
Bill I think they do two grades of plastic, one OEM and the other is not as thick. More expensive i think for the OEM, just depends on weather you want to stick to original.
surely OEM is best .. will last longer and probably fit better too
I'm not so sure. Slightly thinner plastic should fold more easily (particularly when cold), and potentially be less prone to cracking. I will talk to them about it.
Right, it's booked in at d:class on Monday.
The windows are no longer available from M-B. The ones they fit come from the same maker and are physically identical apart from there being no M-B stamp in the corner. Interestingly they are different thicknesses - 1.5 mm for the side ones, and 1.25 mm for the main central one. Total cost for this is £335 plus VAT.
