mystery fuse
grober
MB Master
Perth, Scotland
W204 ESTATE
Posted: Thu Nov 06, 2003 10:00 pm Post subject: Mystery Fuse
I recently found an in-line bayonet fuse holder under the main fuses unit in the fuse box. Red in colour with red wires its fuse was missing. Any ideas what this fuse is for and its rating. I have been told it might be for the alarm system???
Sounds likely, I have seen two w124s with disabled alarms.
Re: Re: mystery fuse
You Manchester boys :p
I'd say you could disable most things by removing a fuse !! - assuming you know where the fuse is !!
S.
Did it hve a tag on it:Attention-especially car thieves,alarm fuse -do not remove.........!
Mystery fuse SOLVED. Previous owner had wired extra driving lamps via relays and this was powerlead!!!
