Help required! I have found a vacuum hose which leads to nowhere. It's on the nearside of the underbonnet area and feeds through the bulkhead panel into the area where the battery sits. The hose is not connected to anything at one end but is joined to a vacuum block (?) at the other. Please see the pics which might help - last photo shows the vacuum block in situ and pushed into the grommet of the battery bulkhead. The other two pics show the hose pulled through into the engine area.. I cannot find any suitable point to connect the blank end to - nothing looks to be missing a hose. Can anyone help? When the engine is running there is no vacuum at the hose blank end.
