uumode
- Sep 1, 2003
- C300 AMG Line Premium Plus
Can this be successfully repaired? (Not using it for racing where the ultimate handling is needed, just around town and to work)
What technique and how much roughly so I don't get ripped off.
Off course I could change the tyre, but that means changing the other tyre on the same axle to the same brand to match the ones on my other axle (I want 4 tyres to be the same).
I could just replace the damaged tyre to match the tyre on the same axle but that would prolong the fact front and rear axles don't match and more importantly this brand of tyre doesn't have a rim protector to avoid kerbing the alloys. So want to really effect a repair until they are prehaps half worn and then all my tyres will co-ordinate.
At the moment the tyre seems stable, perhaps only needing pumping up 2-3 weeks, but it is losing pressure very slowly. However worried that when the nail contacts the road it might disturb the current relatively air tight seal, especially when the tread is worn down a bit more to the nail head.
