Narva Range Power Blue H7
JohnnyW202
2004 Mercedes E270CDI Elegance Saloon, 2004 C200 Kompressor Estate Avantgarde SE Sport Pack
Narva Range Power Blue | Products | Auto Express
Had these in my Avensis, and bought a set for my W202.
Problem is as with my Avensis, even on setting 5.. i.e (Lowest) on the headlight adjustment.
I keep getting flashed, they are excellent bulbs truly!
People even stop at roundabouts and get out, thinking I've got my fullbeam on.
But they're perfectly legal!
Any ideas?
BTB 500
MB Club Veteran
Berkshire
R129 SL500, W639 Vito 120, S203 C230
Is the headlight level adjustment working? Are you sure 5 is the lowest, not the highest?
OP
OP
J
JohnnyW202
Yeah 5 is the lowest, you can see the beam move down... It was the same on my old car... Unless people are just idiots? But surely they wouldn't sell them if they were illegal!
They're a subsidary of Philips too!
stevesey
Bristol
Alfa 156 1.8TS
Not seated properly (so filament is not in the correct place in relation to the reflector).
Although if it the Avensis was like that as well you'd have to be pretty stupid to get it wrong twice. :devil: Could just be poorly made.
How does the cut off look when you drive up to a wall/garage door
BlackC55
Portsmouth, Hampshire.
E55K SL500 E300Hybrid E250X3 Viano C55 E450Cab A180 Smart 44 Brabus
Will it pass an MOT?
OP
OP
J
JohnnyW202
The MOT is what I'm concerned about, but then it's only a couple of quid for some bulbs I guess.
Although these were £20 odd quid.
They're definately seated right, they're just hellishly bright :thumb: Good for me, bad for others?
They seem to be particularly bad for Lorry Drivers, i.e it lights up their high vis in the cabin, or it's right in their mirrors leading to alot of *%*! moments.
I doubt they're badly made.
WDB124066
1996 E320 Sportline Cabriolet x 2
Get your lights adjusted down a bit there cobber. I have H4's in one Cab and they are very good, don't get flashed though!
Shude
Hardcore MB Enthusiast
Cheshire
CLK55 AMG
I put an H7 in upside-down once and it took me ages to work out what was wrong with the beam pattern! Pretty easy to check this.
