Anders
After a lot of consideration I decided to go for a Blaupunkt DX-V, which can be picked up new in Germany for around 1150 euro. I intend to (try) to install it myself, but having read all the GPS related topics I still have a few questions:
1) Assuming I can find the speed pulse on pin 1A (green/purple), how do you tap into it? Do you simply cut it and reconnect/hardwire or is there a more elegant solution, e.g. an adapter?
2) Same for power: cut & reconnect or is there an adapter?
3) Location of the GPS antenna: As mine is an estate, there is no rear parcel shelf to put it, so will mounting it in the middle of the dash by the wind screen be OK for reception?
Thanks!
Thanks!
