Allpag
Hi.
Carried out map update on the navigation system (NTG5.5) of my 2017 E class coupe (C238) via USB a couple of weeks ago and everything appeared to be ok. Update took about an hour to install and vehicle position was showing to be in the correct location after the installation was complete.
I didn't drive the car myself until last Thursday evening when I noticed that although the navigation system seems to know my direction of travel, it is about 2 miles out of position and obviously doesn't match up with the road map.
Spoke with the map supplier and they suggest that this appears to be a problem with the GPS antenna rather than the new map update. I guess that I could just be unlucky that the antenna has failed so close to the map update.
Was wondering if anyone else has experienced anything similar after map update.
Also, when looking at the Compass information within the Navigation system, this shows 12 satellites from which a signal can be recieved - is this the actual number of satellites connected to the system in "real time" or the total number of satellites that the system is capable of connecting to simultaneously?
I can see (genuine Mercedes) replacement GPS antenna available on Ebay for around £50. I believe that the GPS antenna is located in the drivers door mirror in the C238, has anybody had any experience with replacing the antenna?
Thanks in advance, any help/advice would be appreciated.
