Hi
cumblechook,
I've an oil leak on my recently purchased S350CDI with OM642 engine. As E55BOF says most likely oil cooler seals. I'll set out what I've been told so far as it may be helpful. I'm sure more experienced members will correct me if I'm wrong.
I first had the underpanels taken off and took them and the car to D Wynn in Trafford Park M17 1JS 0161 876 5556 to get everything cleaned off so I could see where the leak was coming from. They only take cash and can get very busy so worth calling to get booked in. They cleaned the underside, engine and panels for £25.
There was no leak visible on the engine but the join between engine and transmission (bell housing?) was moist, so the immediate thought was a gearbox out
job to replace the main seal. I spoke to Stephen at Tameside Transmissions who said it was almost certainly the oil cooler seals as he's never known the main seal to fail on these engines. Apparently there's a hole at the front and rear which allows the oil from the leak to enter which means there's no leak visible from the engine.
The oil cooler is buried deep in the V of the engine so it's about a 12 hour job to replace. SPR in Stockport on their website quote £1200, probably plus VAT, to replace the seals. I then took the car to MasterTech Assist In Droylesden, virtually next door to Tameside Transmissions. They couldn't say for definite it was the oil cooler seals without a stripdown, but based on experience they were fairly confident. They quoted £817.30 for the fix - I've not asked yet whether VAT is included. Their labour rate is £55/hr + VAT. I can't give them a definite recommendation since I've not used them yet.
My local trusted mechanic said he'd research the issue and see if he knew anyone who could do it. I'll be seeing him today or tomorrow so will know more then.
There are videos on youtube if you want to see how much of the engine needs to be removed to get to the oil cooler - there's no way I'll be considering a DIY Job.......
