Before jacking the car mark the inclination of the current top arm against the inner chassis leg.
Struts need to come out, I think I disconnected the ARB via one of the drop links to help get more articulation on the lower arm. Obviously the old top ball joint will need to be split.
On my E320cdi I6, WIS says remove the fuse box from the engine bay (!) to access the nuts. A 16mm long combination wrench is sufficient to just reach them, offside more difficult than nearside but the V6 may be different.
Mercedes say you should use new nuts and bolts (for arm and strut mounts) and for the sake of a few pounds I would change them. The nuts are the type that deform on tightening. You will likely need a help on reassembly.
The short cut of not removing the fuse box means that in reality you will be torquing the bolt rather than the nut from within the arch. I worked in the arch, holding the new arm at the correct angle to avoid pre-loading the bush. I fed through the new bolts to engage in the new nuts that I'd taped to the long wrench. This is where the third hand came in! Once the bolt is engaged in the nut it is relatively straight forward.
My car had the older, one piece arm The ball joints were relatively loose but there was no discernible wear in the bushes. I was chasing down a knocking noise which eventually turned out to be the dampers.
