Can someone help me get in contact with someone that can solve a flat spot or hiccup with my car.
As you all can see it's not standard, Kleemann are down south, MB was a classic case of "sorry, computer says no" well, close, the star system showed no faults!!!
Symtom
pull away very slow in 1st (manual mode) press pedal slowly build to 2/3k rpm then big hiccup and back to normal.
pull away in second slowly is the same but less of a jerk
pull away in second quickly (like pulling out on to a round-a-bout) the car then double starts, hard to explain, an immediate flat spot just as the car is pulling away due to the fact that I have pushed the accelerator past the flat spot point straight way.
In reverse it's like a switch.
Is there is some sort of laptop/system like a polygraph that can monitor the car, I only need twenty yards to induce it?
HEEEELLLLLLLPPPPPPPPP!!!!!!!!!!!
Symtom
