Hi everyone
I put a post on here about 1 month ago. It was about the yellow check engine light.
"Hi all
Was driving home last night a yellow check engine light came up on the dashboard - (the light looks like an engine).
Car is fine. Still very responsive. Light still on today.
any ideas"
I got a few helpful replies and went to an independent Specialist in Stockport to have it looked at.
The car was wired up and it appeared that the secondary air pump was at fault. So this was replaced along with the relay. Parts were pricey - £210 + vat for the air pump and the relay was £10.
All appeared to be ok, then 2 days later the light came on again. And let me remind you that there has never been any powerloss, or any symptoms at all from the car.
So back to the specialist and back on the diagnostics. This time it showed that the intercooler pump was at fault, so we did some research and decided to try the ford lightning intercooler pump. (from other posts i must say that typically the intercooler pump presents with power loss rather than a engine management fault). Any way car fine and again performing perfectly. 2 days and 20 miles later, the light is back on!!
I am going to go back to have the diagnostic check on monday - from I must say a very helpful merc specialist. It is also worth mentioning that all the wires were checked and there appeared to be no short circuits.
I would really appreciate any thoughts though at this point as to what could be wrong???
Al
"Hi all
any ideas"
Al
