Need part number for 'bit' on C220 W203 (2003)
omega1
Hampshire
E400d 2019 4matic (C238)
Hi all,
This is goign to sound a bit vague!
I noticed that on my new (second hand) C220 CDI (W203) 2003 there was a noise coming from the front offside of the car which I thoguht was a flat tyre, but turned out to be that there is a piece of plastic that had come loose which the wheel was catching on and has now worn through. I'll try and explain it better (should have got a pic, I know!), so I need a part number for it to try and find a replacement...
OK, front wheel, offside. It is a black piece of plastic that, if you look at the wheel, is directly in front of it (same height) that is screwed to the main under part of the front of the engine and it seems to protect a water canister that is behind it, it goes from the wheel arch (in front of the wheel) to right under the front of the bumper (which is where it has broken off). It is just some kind of plastic cover.
Sorry for the very vague description, but does anyone know which bit i'm on about or shall I come back with a pic?
I'll need a part number so that I can start hunting for a replacement, have bodged it in the meantime...
Thanks in advance.
Hi all,
Thanks in advance.
Êàòàëîã
Part 110?
Looks more like part 130 to me... Its a large piece of plastic, sorry, I know im being very vague but cant explain it better, i'll get a pic.
Hi Nick,
Thanks for your help, much appreaciated. I'll get a pic of it, hopefully you will be able to confirm it. This may sound liek a daft question, but is the passenger side the left side or the right side? or is the one youve linked to the right one (passenger) side?
Thanks again.
Hi Nick,
Thanks again.
N/S = left
O/S = right
So the link is for the O/S cover.
