Need Price Estimates for the following:
hassanmk
Ok, the following are for my 2003 C180K SE Avantgarde :D
Xenon Headlamps
Sat Nav
7CD Changer
Thanks lots in advance :p
miro
Sydney NSW Australia
W203 slightly modified
Xenon Headlamps
Sat Nav
7CD Changer
I found myself that it makes a huge difference on the cost of the headlamps which country they are for.
The Xenon retrofit isnt the same as the factory install. For one thing the squat sensors on the rear suspension are not usually installed, the new bumper with headlamp washers is not installed and the old vacuum adjustment on the old headlamp angle needs to have a Xenon bracket fitted - which is not easy to obtain as only a small number of people are capable of finding the old parts to fit into the new system.
With the SatNav you need to be sure that you are buying the correct version. The cabling, installation and setup is not such a huge problem.
MBenzNL and Braybrooks are popular in this forum.
MBenzNL
the Netherlands
1993 C250D - 612+k kilometer
I haven't seen a 7 CD changer ever...but as far as the other items are to be concerned (satnav and bi xenons) I have them both on stock (new bi xenons for the 203 sedan) and refurbished SATNAV (comand and APS30)...
greetingz,
