chizzel89
- Mar 29, 2010
- Location
- Pembrokeshire
- Mercedes-Benz C250 Turbodiesel Sport est. 155,000 mls. Peugeot 405 1.9 GLX TD Estate- 280,000 miles
Traced the trans fluid leak on my C250 to the multi-plug. Box behaved normally despite having lost nearly a litre of fluid over the last 10k miles. Its been kinda oozing away.
The fluid, filter and sump gasket were all done 10k miles ago, so I'm just doing the multi-plug and getting the fluid level just right.
Has anyone done this and could they give me a 'how to'...
Which way to twist the beige plastic plug etc... what holds it in.
The car is up on ramps at the front so it shouldnt loose much fluid and I have a tub of comma MV ATF (which meets all the relevant MB specs) ready, and ofcourse a dip-stick.
Is it worth checking the other end of the multi-plug lead for oil contamination? How do I do this? If I find oil, do I just spray loads of contact cleaner on there until it dries out?
thanks in advance.
thanks in advance.
