Nigel Cuttell
I have a nice 124 220TE estate with blown engine. I am planning to transplant a 220 CDi diesel engine and auto box into it (from a recent write off W210 or W211 or C Class). I expect I will need all ancilliaries as well to make the job easier (including ECU and engine wiring loom). Has anyone any knowledge of whether the swap will be straightforward mechanically (eg. will the gear shift lever be in the right place; will the engine mountings need inventing; will the prop shaft be the right length etc.). I also wondered if anyone has a list of axle ratios for 124 models as I will probably need a much higher ratio for the diesel.
Any thoughts, advice, data appreciated.
