dozypillock
Just spotted in the press release about the new E63 gearboxes. The 9 speed, I believe, and that it has several modes. I am merely questioning one of them.
"Comfort" is the well-balanced drive program with a comfort-oriented suspension and steering set-up, as well as a fuel-efficient powertrain configuration and early upshifts – including smooth gear changes and a discreet engine sound. Cylinder deactivation, ECO start/stop function and gliding mode are on. When the driver releases the accelerator in a speed range between 37 and 99 mph, the clutch of the MCT transmission opens and the engine is decoupled from the powertrain. The electronics reduce the engine speed to idle level, and the motion resistance is reduced by the compression and frictional forces of the engine in overrun mode.
The bit in question is "When the driver releases the accelerator in a speed range between 37 and 99 mph, the clutch of the MCT transmission opens and the engine is decoupled from the powertrain."
I was always taught that the engine must be connected at all times. Even coasting is advised against, if not actually illegal?
Neil
Neil
