New Vito owner replacing audio 5
njcoe
Hi all,
I've just bought a 2008 Vito 109 dual liner, which I am very pleased with.
I'd like Bluetooth however and wondered if I bought an audio 20 off eBay would this be straightforward to swap? Any extra bits required? Would I need to take to Mercedes to reprogram anything?
I have a standard stereo with Bluetooth that I could fit with adapters and fascia but would prefer the look of the audio 20 of this is viable...
Thanks in advance for any help, sorry if this had been asked 100 times before but couldn't find a definitive answer anywhere.
Audio 20 is the way to go, its not quite plug and play as you need quadloc to wire it and a mic, all easy enough.
You need a frame.
Bluetooth antenna.
Quadloc adapter.
They sound great and look good, then later swap to NTG2.5, there great and with a gps antenna will swap for the audio 20.
Thinking about it, you will have a frame, just unclip the bottom part out.
