Is that engine in the second model SLK? Was looking at the SLK 200 which is a 1.8 engine .Avoid cars fitted with the M271 engine (petrol, 1.6/1.8L, 4-cyl), unless the timing gear has been replaced.
According to Wikipedia it was fitted to the SLK as of 2002:Is that engine in the second model SLK? Was looking at the SLK 200 which is a 1.8 engine .
Mercedes-Benz M271 engine - Wikipedia
The M271 was superseded by the M274 as of 2013.
So petrol 4-Cyl SLK made between 2002 and 2012 will have the M271 engine.
Google "M271 timing chain failure".
Said that, you could opt for a low mileage car with FSH, then have the timing gear (camshaft sproket wheels, chain, and tensioner) replaced by a specialist.
GoodThanks for that. Will look for the next size engine up and steer clear of the 1.8 now .
Minimum 3.0 now. Glad I asked the question now.Good
I barely has enough power to fold the roof
Larger engines can be surprisingly economical as the torque allows for lower rpm on overtaking and general cruising plus the torque does make the whole experience more relaxing.Minimum 3.0 now. Glad I asked the question now.
