Hi there,
I am a newbie to this forum. Have just joined as I have 2 merc clk my wife has a 230 komp Ive just bought a clk 430 year 2000.
So I think I might be using the forum a lot more.
I am having some problems with it and wonder if anyone can shed any light. the dashboard is lit up like a christmas tree !!!
The abs,bas,esp,brake warning light come on with the ignition,and stay on as soon as you start the car and dont go out it also says esp defective visit workshop on the dash display. when driven speedo is not working,and gearbox is in one gear suspect third as does 30mph at just below 3000rpm limp home mode I think. tip shift dosnt function.
Can a faulty speedo sensor cause all this (no speed signal) ?
If so where is it located and how can I test it. Any help ideas welcome. I am hopeing it may be something simple,or worst case the esp bs unit and ecu. I also thought I might be able to swop some parts off my other clk if they are the same for testing. Also hood has an issue as well when you release the latch the windows go down but then thats it, the red hood switch also is not illuminated and when you push it down at the front of the switch there is no spring restistance,also when unlatched the hood dosnt move up that first few inches under spring tension. could ther be a spring off or micro switch issue,can they be tested and where are they located ? Or could it just be the hood switch is it fused ?
I would greatfully recive any advice I am located in the oldham area and willing to pay beer tokens for any help from anyone local who may be able to take a look at the car,but dont want to drive it to far in limp mode.
i am also happy to do some testing myself nut need some idot proof instruction to follow!
Thanking forum members in advance for any help advice.
Appreciated.
thanks
Simon
Appreciated.
thanks
Simon
