Hi I am new to the forum but have owned a lovely (now 60k) 1995 Sliver W124 320 convertible Sportline since 2013, which has only really ever been used during the summer and we love it, that's me the wife and the 2 dogs.
I would like advised/help if possible on the following:
Issue 1.
Water in the front and rear passenger footwell -
This is clean water and only appears when it rains. I have had it checked and nobody can locate where its coming from even with a hose at full blast!!!
I have been told all the drain holes are clear but as I don't now where they are I don't know how to double check. Under the battery tray is fine so it not from there!!
Issue 2. Ignition switches on but can not turn over the engine:
I have had it in 2 garages and after a hefty bit of cash being spent neither of them can locater the relay, apparently during the period mine was manufactured for one year the relay was moved but there are no records as to where on the car!!! So I am now very modern and now have a starter button fitted to bypass the lost/missing relay. I the issue is kinda sorted I would like to get it back to how it should be.
Unfortunately the last garage left the original handbook pack in the rear passenger footwell and with issue 1 above they are all ruined!!!!
Issue 3. Blower/Fan motor not switching working - it appears not to be the fuse.
I live SW London if any can recommend an independent Merc specialist that would be great, I have used SS motor in Weybridge in the past.
Issue 1.
