Looks excellent
Where did you get the fog light bulbs? Are they completely error free and do they work with the ‘follow me home lights’ ?
Won't those drls dazzle oncoming drivers at night, being 50w leds and mounted so low down?
They should be extinguished when headlights are on, but these appear to be replacement foglight bulbs with no mention of a drl control unit and thus still under manual control from the lighting switch.
I fitted my H11 a while ago - just buy a separate set of resistors (50W 6Ohm), H11 plugs and non-CANbus* LED/COB bulbs - it's very easy to put together your custom harness, plus you can add an extra plug to run the light from a DRL controller - that way it'll be fully compliant with the current regulations, and you still keep the "follow me home" function. Add a 1N4004 rectifier diode in fog line positive.Hi i would love to fit these type of bulbs in my fog lamps i wonder if they do them for the E class facelift i think they are 12v 55w h11.
On mine, the monitoring is all within the light switch, which could be termed a SAM I guess, and there is a single wire from the switch to the cluster to throw up the bulb out error. Years ago I had a Mondeo and that would tell me exactly what door was open, what light had failed.* Bulb monitoring is done by SAM, but LEDs with built-in resistors routinely called "CANbus", so I use the same terminology.
This comedy post didn't receive the credit that it deserves.Drls do not operate at night?
On cars fitted with LED/HID headlamps, the DRLs are dimmed (but not switched-off) when the dipped beam is switched on.Drls do not operate at night?
I think the idea was to 'convert' the foglights to makeshift DRLs?If it's foggy, those LED fogs will be virtually useless BTW due to the colour temp in the day.
you turn on one of them first, can't remember if it's the front or rear, then 'add' the other.
Yes I think you are correct, IIRC it’s the rear that turns on first as you pull the switch ‘out’ and then the front?
So in the case of the OP, how will the fogs operate as DRL? EDIT too slow..... /EDITYes I think you are correct, IIRC it’s the rear that turns on first as you pull the switch ‘out’ and then the front?
