no acc power
Discussion in 'Electronics' started by elviscymru, Aug 15, 2008.
  1. elviscymru
    elviscymru New Member
    7
    Aug 15, 2008
    West Wales
    Car:
    E220 cdi
    On my e220 cdi yr 2000 the after market dvd player doesnt go off when i remove the key. pulled the head unit out,its not connected to the acc lead, the acc lead is dead. Is there a fuse for this ? If so anyone know where it is ?
  2. alibally
    alibally Active Member
    220
    Jun 8, 2008
    edinburgh
    Car:
    W169 A160 and Smart 451
    There may not be an acc power supply at the radio as the cars with the steering wheel controls only have a permenant feed in the plug . The radio gets its on off for ignition through the body can network. (CAN B the brown and brown red ). Not to be confused with earths wiring!!!!
    You can pick up a acc feed at the cigar lighter if you want one.
Tags:
Share This Page
