PeterW1966
Hi All,
My first post here. I have done some extensive searches but apologies if I missed something already posted.
I bought a 2004 SLK 230 (R170) about a year ago. At the time (foolishly) I had not spotted that the engine management light was not coming on when the key was in the IGN position. Once I spotted this I checked for fault codes with a code reader and nothing was showing up. The car runs well with no obvious faults. I also pulled the connector off the MAF sensor (which I understood should trigger the engine warning light) - nothing.
Whilst I thought it was unlikely that the bulb had blown I bought a new bulb and today I went about changing it. The dash removal was surprisingly straight forward, which was a relief. However, I checked the engine management bulb and it looked fine. I replaced it with a new bulb and still no light with the key in IGN position.
Now here is something that worries me even more. I also changed the front discs and pads today. The pads were very worn, to the point where the wear sensors on both sides were clearly worn through (showing metal). However, I have not had a warning light come on for this. The brake wear warning light does come on with the key in IGN position (along with all warning lights apart from engine management light). They all go out once the engine is started.
So, I am trying to find out if there is some know "bodge" that a previous owner may have done to hide an engine management light triggering fault? Or is there a known issue that could effect all warning lights? I did try pulling the connector off the brake fluid reservoir and this didn't trigger a light, but maybe this is normal.
Any ideas or suggestions will be gratefully received.
Peter
Peter
