No Pre Filter - is this normal? S124 300td
Timster
Scottish Borders
Currently Merc' Less.
There doesn't appear to be a pre filter in the fuel system of my S124 300td.
Is this normal, or have I missed it?
SHould I fit one?
Ta
it should have one - if it doesnt have i'd definatly fit one, otherwise you're relying purely on the in tank strainer before the main filter which cant be good.
Hi
Yes it should have a prefilter, it is normally located below the inlet manifold down near the left hand engine mount, it is a little in-line throw away filter, some are straight through and some have a 90deg bend on one side.
Not hard to fit one if its not in place. Best done from underneath.
Hope this helps
230K
sorry for the very late comments .
you can clearly see when you remove the air filter cover on the 12 valve 6 cyclinder diesels. Its has a 90 degree bend one one side . so when you are changing or cleaning the air filter you can change or inspect the in line filter . its a piece of cake once from the top once the air filter cover is removed.
Its better late than never.
