No pressure in cooling
topliner
Hi, I changed the thermostat on my car yesterday and renewed the coolant, I ran the car up to temprature initially the guage stayed at 80 degrees. I then took the car it for a drive and the guage showed mid way between 80 and 100 degrees, the heater is blowing hot air but what puzzles me is when the car is at normal temprature there is no pressure when undoing the radiator cap. I have since driven 200 miles with no signs of over heating or loss of coolant. The radiator cap was fine before the coolant change and the thermostat is a wahler bought from ECP with the identical mercedes part number on it.
As always I appreciate your help and advice.
Is the stat the same temp rating as your old one?
You may simply have an air lock. Start the engine from cold with the coolant off the car. Get the front of the car as high as you can (use ramps if possible). Leave the car running for 45 minutes as idle with the ca still off. This should 'burp' any air in the system.
Do not be tempted to peek into the header or rad when doing this :^) It is at that precise moment that the car will burp and you will not find it funny.
I'd change the rad cap.
The same happened to me. Just disturbing it may have finished off a degraded seal
Hi and thanks for the replies,
the thermostat is the same rating as the old one, I will try the bleeding process as described.
The radiator cap is what I will try after I've rechecked there are no air locks.
It"s not over heating or boiling over.
Did you run it up to temp with the cap removed initially in order to check level constantly? ............... then I would say your experience is perfectly normal.
I would first allow the vehicle to cool completely with the cap off ........... check level and refill to correct level when still hot, then, with the cap still off again recheck and fill when cold. Fit cap when cold and drive till temp gauge shows normal operating temp.
Do not open expansion tank now .................. leave it to cool. When cold remove cap and check level ........... if normal fit the cap and repeat for a few days while thinking of flowers and beer and forgetting pressures
What's the car? My R129 SL500 was exactly like that.
Hi, it's a w211 E280 CDI with the V6 OM 642 engine.
Not at "80 to 100 degrees" it won't; especially if there's anti-freeze in the mix.
My point being that pressurised water boils at a higher temp.
THIS! ............... and the converse is also true - iow - you cannot have the water in the expansion tank at any temp above the locale atmospheric boiling point of water if its not pressurized......... implication being with the cap off and the water not seen to be boiling, the water temp is obviously not anywhere near the boiling point of water at that geographic locale ........... water boils unpressurised at sea-level at 100C and way earlier the higher you are above sea-level - see Boiling Point of Water and Altitude
also
The radiator cap was fine before the coolant change....
As defined by what characteristics observed?
As defined by not leaking, presumably...
