minghan1986
- Sep 8, 2013
- e200 kompressor 211
i have a e200 kompressor auto transmission,211 in 271engine model,my problem is when idling is rpm800,once put in d position,the rpm will drop in rpm600,then the car will be vibrate,and from d to n position,the rpm will highly going to rpm1200 and drop back to 800.the car is driving smooth in flap road,but when u stop at the uphill,in d position,that was like no response on accelerator,even in full pedal,the car still cannot move.i am a specialist in mercedes car too,the car dont have any fault code.was change throttle actuator,accelerator sensor,mas air flow sensor,timing gear and chain complete,air throttle actuator,intake manifold.
