No warm air from heaters
tiern8546
2003 sl350
Hi,i have a 350sl 2003,the heaters no longer blow hot air only cold is there some kind of solenoid valve to allow hot water through any advice would be great
Assuming you don't have a climatronic system then it sounds like the duo-valve is stuck or not operating. Before you go delving too far, check the fuse box and also the coolant level.
+1 duo valve or air in the cooling system. Does the car get up to operating temperature quickly???
hi thanks for replying the car gets up to temp as normal,coolant level is good,will look for fuse do you have any idea of location please
