noise when turning left
pricega1
Lincolnshire
2014 SLK 200
I own a C180 Kompressor on a 52 plate. Everytime I turn a slow left hand corner There is a noise coming from the right hand front (could even be behind the dash, can't tell for sure). I sound like a creaking wooden door!! (the car is not that much of a shed :)) I've recently had the n/s front coil spring replaced after it broke, o/s front coil spring was replaced last September after it too broke, made no difference whatsoever. Thought it may be a supension issue that's why I posted it here. The car has only done 40k as well. It's dooin me 'ead in :wallbash: Any ideas?
Could be a dry bush or a collapsed one. Have a gook look starting from the suspension arms upwards
did anyone hear of the american woman who would only do right hand turns
seriously
Maybe a squirt of wd40 around the steering column where it goes through the bulkhead through the rubber grommet.
Lynall
Roll bar bush?
Cyclist in blind spot?
