May 10, 2012 #1 G gtvlusso Active Member Joined Dec 22, 2009 Messages 322 Car Bicycle and a couple of ML's Hi All, I have a noise, mechanical whine from the PAS. I am preying that the pump isn't about to have an embolism..... Fluid top up or cheque book at the ready - any thoughts?
May 10, 2012 #2 Terry_ Auhorised Forum Sponsor Joined May 26, 2011 Messages 1,897 Location N/W london Car C63 Wagon in black Pumps do fail on ml's. check fluid level first
May 17, 2012 #3 OP OP G gtvlusso Active Member Joined Dec 22, 2009 Messages 322 Car Bicycle and a couple of ML's Fluid seems to be okay - still feels a bit mechanical and whiny, any idea of cost of replacement?
May 17, 2012 #4 BlackC55 Authorised Forum Sponsor SUPPORTER Joined Feb 8, 2007 Messages 20,767 Location Portsmouth, Hampshire. Car E55K SL500 E250X2 Smart44 Brabus Track car E450Cabriolet X350 Pick up Fill up above the max. They often quieten down then. If not then a new pump is needed.
May 18, 2012 #5 OP OP G gtvlusso Active Member Joined Dec 22, 2009 Messages 322 Car Bicycle and a couple of ML's Is it safe to overfill the PAS fluid? Should I fill it way over the max?
