GSMGuy
Well, after all the faults being repaired on my ML - Just got it back after a month at the stealer - all 5 injectors fitted with new seals (again) - apparently they have modified the seal to a compressible washer from the original solid one.... Also the EXPENSIVE alternator replacement... Anyway... The cat started rattling... And at £700 for part alone..... I decided to take matters into my own hands.....
So:
1st step was to remove it from the car, so up on the ramps, a quick spray of WD and away it came - trickiest part was the clamp to the downpipe - Merc have a special tool, I used a 6" G Clamp and a screwdriver.... Same to replace... Perfect
Here is the offending item..
Now to open her up, I chose to open the top so that it would not be visible from underneath the car, I made 2 pilot holes....
Which I then enlarged so I could get my trusty jigsaw in..
Then cut 3 sides of a rectangle..
Before folding back the flap.. And revealing the substrate, mine hadn't broken up - yet, was just loose in the can and annoying me - sounded like a bag of nails...
Used a 19mm spade bit in the cordless to break up the core, took 10 mins..
Leaving the inside all clean - I noticed there is nothing to stop fragments from a broken up cat from passing out into the rear silencer or getting sucked back into the turbo...
Bend it back into shape..
And then had it TIG welded at a local engineering firm - they welded the flap and put a plate over the top just in case...
How neat is that welding!!!
All fitted back, and definate perfomance increase, and no nasty rattle!!!
The cost?? An hour of my time and £20 cash for the welding - BARGAIN!!
Mike
So:
Mike
