Nokia 6230i compatible with 6230 UHI cradle?
RobCLK
Melbourne, Australia
MY05 CLK320 Cabriolet
Does anyone know if the newer Nokia 6230i will work in the 6230 UHI cradle.
I have not tested it, but I was about to buy a 6230 when I found the new 'i' version is now available with 'Push to talk' function amongst some other improvements.
Keen to know if it works correctly and interacts with steering wheel buttons and COMAND just as well as the older 6230.
Yes it will work as long as you have the right bracket.
Part No: B67 87 5846 should do the trick for you as this is the latest cradle from Merc.
