non starting W210 300TD HELP reqd please
Discussion in 'Engine' started by BIG Sean, Aug 14, 2008.
  1. BIG Sean
    BIG Sean Active Member
    550
    Feb 23, 2006
    Bolton
    Car:
    Chrysler 300c SRT Design CRD
    my mate[an old school mechanic] bought a cat d S/R 1998 e300td, that wasn't running [no key]he traced previous owner, got her to get new key from MB Blackburn and all was working fine.
    Leaves it for three weeks or so, then won't start, so charges battery, turns over but still won't start, a bit low on diesel so he puts 10L in, still won't start but is turning over, he is getting fuel to the pump he has checked, but is stumped as to what could be the problem.
    Could the immobiliser have kicked in when battery flat or something? anything else? what else can he check or do?
  2. OP
    OP
    BIG Sean
    550
    Feb 23, 2006
    Bolton
    Car:
  3. rpe2
    rpe2 Active Member
    400
    Aug 6, 2006
    Silchester
    Car:
    2010 E350 CDI, 2016 Ford SMax
    Check for air in fuel lines, if you can see bubbles then you have a leak, replacement of lines not expensive, just fiddly.
    Think tha there's a 'HOW TO@ on here somewhere
    Richard
  4. DrNick
    DrNick Active Member
    507
    Nov 25, 2003
    Yes, sounds like an air leak. On mine you could see the bubbles in the clear fuel lines. You might get it to go by topping up the fuel filter directly with diesel, or cranking for ages on a good battery to prove the point, but the long term solution is either new seals on the clear pipes or just fit new plastic pipe assemblies.
    Mine was a lot worse if I left it pointing up-hill!
  5. spock500
    spock500 Active Member
    727
    Apr 1, 2008
    Milton Keynes
    Car:
    S124
    Could be air but they usually start after a bit of cranking, if its the alarm gone wonky it would disable the fuel solenoid which is part of the IP --
    Best (and easiest) way to check is pulling the rubber bleed pipe to the filter off, its a push fit, then getting someone to crank it over -
    There is no other way to immobilise a diesel other than stopping the fuel, you can of course disable the glow plug but it will still start albeit lumpy.
    Also check pre-filters if vehicle has been standing for a bit.
  6. Dieselman
    Dieselman Banned
    34,206
    Jul 13, 2003
    Car:
    Peugeot 403 Convertible
    I take it this car has the later electronic key and ignition lock and that when the key is inserted it releases the steering lock and allows the engine to turn over.
    If so forget anything to do with the immobilizer as that is part of the ignition switch and must be working if the key works at all.
    It has to be air leaking in or the crank sensor gone. The CKP can be checked using a voltmeter connected to pin13 of the diag connector.
  7. jaymanek
    jaymanek Authorised Forum Sponsor Authorised Forum Sponsor
    16,412
    Nov 29, 2002
    Nuneaton Warwickshire
    Car:
    We had a similar issue which in the end turned out to be all five glow plugs dead!
  8. spock500
    727
    Apr 1, 2008
    Milton Keynes
    Car:
    S124
    Ok, going to go out on a limb here and say its one of (or both) of the pre-filters -
    Here's the theory;
    Car has been in a minor shunt dislodging gunk in the tank which has then been pumped into the filters, left to ferment for three weeks and bobs your uncle :)
  9. OP
    OP
    BIG Sean
    550
    Feb 23, 2006
    Bolton
    Car:
    car was stood in scrap auction for over a month - transporter delivered got key a month or so later - it started and drove for a while then wouldn't after battery going flat.
  10. spock500
    727
    Apr 1, 2008
    Milton Keynes
    Car:
    S124
    Posted this on another thread, red spot is pre-filter on OM 605 so should be the same of 606
    [​IMG]
    Single 10mm bolt and the whole plastic holder comes out, here's mine :eek:
    [​IMG]
Share This Page
