Noob question Re Jack/Tyre inflation foam.
Magnu
Brighton
C43
Sorry for noob question but searching forum and internet doesn't give a clear answer.
I picked up a new (3month old demonstrator) C43 earlier this week. My car has an empty void under the collapsible crate in the boot and I can not find any tools anywhere. Should the car come with jack/tyre removal tools or tyre inflation foam?
If anyone is able to clarify I would be grateful.
Cheers,
Jon
I would expect it to come with the tyre foam and electric portable compressor on that vintage but not sure if that was "an option".
Well my understanding is if your car has no spare wheel be it full size or space saver then your car will have the tyre inflation foam,you should be able to see where the inflation kit should fit
Have you got run flats fitted? If so you may not get all the tyre repair stuff as standard.
Id invest in a spare and jack ASAP. Regardless.
The datacard should tell you what was there when it left the factory,
My C250 came with bugger all , except runflats. I bought a can of tyre foam when I put non runflats on it.
