Hello,
I've some NOS Mercedes parts which might be of interest to members, most of the parts are new old stock. I have attached pictures of some of the parts but please email me if there's anything you are interested in. Can post most items worldwide.
List below:
A0000901451 Fuel filter New
A6460920501 Fuel filter New
A0024205920 Brake shoes New
A1021840501 Oil filter New
A6110920101 Fuel filter New
A000180160910 Oil filter New
4220920005 Fuel filter New
A1041800109 Oil filter New
3183220250 Anti roll bar bush New
1243260116 Bar & bush New
6012670297 Gear stick gaiter New
A0008205321 Truck light housing New
A1232910082 Brake pedal rubber New
87001050 Cluster plastic Used
A0002900912 Clutch master cylinder repair kit New
A0002904567 Cylinder New
6023240050 Spring rubber bushing New
6733200050 Spring rubber bushing New
A0008219960 Front heater unit New
A6017250024 Rubber seal New
A6171800009 Oil filter New
A0000901151 Oil filter New
1238110361 Wing mirror New
2014100581 Rubber mounting New
A0000901551 Oil filter New
A6040940604 Air filter New
A3661800809 Oil filter New
A0020947004 Air filter New
A0020943104 Air filter New
A0020941704 Air filter New
A1150940004 Air filter Used
A0024772701 Fuel filter New
A0030943804 Air filter New
A002094310467 Air filter New
A1244200720 Brake shoes New
6017500159 Cable New
6010940404 Air filter New
A1243506408 Subframe bushing kit New
1020945882 Crankcase breather hose New
A1020501011 Timing chain tensioner New
A0025864442 Brake caliper repair kit New
A9017600047 Door mechanism New
A1235421644 Speedo drive New
A6010703933 Hard fuel line New
A6010703833 Hard fuel line New
A0012956006 Cylinder New
A0012954407 Clutch master kit New
A2034640118 Airbag ring New
A0008006975 Door lock vacuum New
A1248002275 Boot lock vacuum New
004626010102 Rear spring bolt New
A1264600061 Steering seal kit New
A2014900037 Exhaust bracket kit New
A0002903767 Clutch slave cylinder seal kit New
A2024920344 Rubber New
A6753260581 Torsion bar bush New
A3192920082 Clutch pedal rubber New
6013210305 Bush New
2013234985 Bush New
9013260081 Bush New
50315032 Front shock absorber bush New
6010940391 Rubber New
6023260282 Rubber bush New
6733260681 Bush New
1243234985 Bush New
1233520585 Arm bush New
1263520165 Arm bush New
3093200073 Stabilizer bush New
1072910182 Brake pedal rubber New
A9013200289 Rod New
A9013200389 Rod New
0063270037 Control arm bush New
Various Headlight wipers
A0009973320 Washer plug New
A0109972447 Sealing ring New
2028690021 Washer bottle pump Used
A6703510425 U bolt New
408 Wheel stud New
A6114600147 Signal plate New
A0049813810 Needle bearing New
1248260100 Headlight fitting kit New
A0018352306 Resistor New
A6737200275 Handle New
1264630066 Steering bushing New
A3634630153 Spacer tube New
1246900362 Rubber trim New
A1233230416 Anti roll link New
A1163331053 Front control arm bush sleeve New
2035451701 Fuse box Used
0300055103 Ignition cable end New
A1100500167 Valve seal kit New
1233004630 Linkage Used
0290004505 Ignition distributor cap & leads Used
0001411725 Idling speed adjuster Used
1020945782 Rubber hose Used
10209449 Rubber hose Used
A0034201520 Brake pads New
A6704235511 Brake liners New
A0018260581 Headlamp insert New
Monroe 43009 Shocker New
A6013201031 Shocker New
Monroe 53005 Shocker New
A1233261600 Shocker Used
Front shocker 124 New
A0018200445 Wiper blade New
A6707401737 Hinge New
A6707401937 Hinge New
A6707401837 Hinge New
A6707402037 Hinge New
A1266904240 Trim New
A0028607685 Sprinter seatbelt New
A0028204456 Sprinter side marker lamp New
A0075459932 Glow plug relay New
1248100979 Mirror cover trim New
300D tickover cable Used
300D stopper cable Used
SMT1091 Handbrake shoes New
A1264600604 Steerling lock barrel New
Broken indicator lens W126 Used
Broken indicator lens W123 Used
24425r19 Front lens New
34481R19 Front lens New
1305620591 Front lens New
1305620989 Front lens New
0263217 Rear lens New
1248690272 Washer cap New
0105456728 Junction box New
A0012956807 Clutch cylinder New
6012000770 Tensioner pulley New
2018210247 Relay flasher unit New
A1244622130 Steering lock barrel New
A0000900751 Filter element New
A0000902051 Filter element New
6014230886 Boot New
A601010481 Rubber pipe New
A6110530101 Intake valve New
A2203520227 Joint New
A2017600202 Window winder New
6673200073 Rubber bush New
6737500259 Bonnet cable New
A6418104716 Front mirror New
1248260043 Indicator lens New
1092835 Water pump New
0055456424 Wiper relay New
0035440732 24V relay New
A0049812125 Bearing New
A0069979346 Seal ring New
A3853500168 Seal ring New
A2014920116 Rubber New
A2103203689 Drop link New
A0019813518 Roller bearing New
A1074920082 Rubber ring New
1242401517 Engine mounting front New
6016900762 Window rubber New
A1155450142 Safety switch New
115 Clocks Used
1245437621 Clocks Used
1235421441 Instruments Used
1235425701 Instruments Used
1264640017 Steering wheel Used
9043261081 Bush New
9043260881 Bush New
0001592842 Plug cap New
6733200050 Bush New
0001580785 Cover Used
0390341077 Wiper motor Used
1232414113 Mount New
U bolt 308D New
Steering wheel center (W123?) Used
2018110241 Mirror Used
A0004234010 Set of pads New
6695050055 Rad cowl New
4F102 Lower wishbone Used
I have multiple of some parts such as the suspension bushes/rubbers, just pm me with the part number to check.
List below:
6013210305 Bush New
2013234985 Bush New
9013260081 Bush New
6733260681 Bush New
1243234985 Bush New
A9013200289 Rod New
A9013200389 Rod New
408 Wheel stud New
6014230886 Boot New
115 Clocks Used
9043261081 Bush New
9043260881 Bush New
6733200050 Bush New
U bolt 308D New
