Martyn_n
Ok, apologies in advance but this is not a Mercedes issue. It's because the Citroen forum is useless that I turn to yo for advice!
A couple of years ago I had some (Ultimately unnecessary) work carried out on the gearbox of my citroen Picasso (Clutch, flywheel, actuator pack and drive shaft). The car has only completed about 12k miles since and has progressively lost synchro on 5th and 6th gears. I thought this was simply bad luck at 82k miles but accept that PSA may not be the best at producing gearboxes. As it's an electronically controlled manual box (EGS) it's virtually impossible to drive as you cannot ease the gears in.
I thought it may help if I changed the oil to something ever so slightly thicker in order to get a few more miles out of it, nothing ventured and all that!
Well today I set about changing the oil, this is where it got interesting. Whilst I wasn't surprised at the shiney brass hue to the oil from the synchro or the debris on the magnetic plug from the crunched gears I was shocked to find 3 litres of oil in the bowl, the capacity of the gearbox is 2.1l (2 for a change) and the guidelines are very strict about not over filling.
Clearly when the dealer did the work all that time ago they had put back 50% too much oil.
So two questions. Firstly could this over filling be the cause of what I think is premature synchro failure and secondly if it clearly is would I have any claim against the dealer after such a length of time?
Thanks in advance for you time.
Martyn
Martyn
