Note for S212 air suspension DIY repair and replacement
jeffpan
Scotland
E350CDI
Disclaimer:
This post is NOT an instruction.
This post is only to share my experience.
You should always seek advice from an automotive professional.
Background information:
2012 Mercedes S212 estate with air suspension on the rear axle without adaptive damping control.
The car is E350 CDI but shares identical parts across the 212 platform.
The car has done 223000 miles mainly in the UK.
The car has full Mercedes + Mercedes specialist service history.
Symptoms:
About three month ago, when it’s very cold, the rear drops together overnight. Then it becomes more frequent, will drop like 5mm per hour. The compressor still kicks in to rise the car and it will be fine throughout any journey.
The story:
I did a lot research online, YouTube, FaceBook, forums as well as speak to Mercedes main dealers and specialists. The conclusion is it could be anything or everything. So I am back to square one.
It is clear there must be a leak (or leaks) somewhere in the system. The hardest part is to find it. Unfortunately in my case the soapy water I made did not show any leak around the compressor, pressure lines, fittings and around the bags. The conclusion is there must be a micro leak, or micro fracture somewhere.
With main dealer rate at £110+VAT per hour and local independent not far off, I decided to take matters in my own hands.
The investigation:
This is probably the most time consuming part of the whole process, is to find what is faulty.
My soapy water test did not show anything previously and it was very difficult to see when the air spring and lines were on the car, as most of the pressure line to the right air spring is hidden behind exhaust heat shields.
To get to the bottom of it, and not to do the job more than once, I decided to remove both air spring and the pressure lines off the chassis.
By the book you should use Mercedes diagnostic system to release the pressure from the system before carry out any work on the pressured system, I just use common sense and slowly loosen the fittings at the valve block. Just before I release all the pressure, I unscrewed the bigger pressure line at the pump end and dipped that end into soapy water, waited five minutes there is no sign of air leaking from the valve under the pressure from the bags. So I think valve units is unlikely the cause of the leak.
When the pressure is gone, I started to un-route the pressure lines from its cable ties, I later decided to replace those factory zip clips with universal brake pipe retaining clips and some zip tie tricks I learnt over the years. This is to keep the pressure lines from rubbing with each other and help them stay in place.
To remove the air spring is easy if you know what to do. When the pressure in the air spring is gone, the rear suspension retract to a position you probably will struggle a lot to get the bags out. I did not have a helper so I put one wheel nut back into the hub, put on the 17mm deep socket and use a metal tube (conveniently the one from my jack fits) to extend the leverage. I just sat on it and removed the bags with ease.
With the bags and lines attached and dipped in a bucket of water, I found the leaks in no time. Both bags and the line are leaking. The pressure line to the right has a microfracture. Both air bags are leaking from the crimp rings. The leaks mainly concentrated at the bottom crimps and exactly where the rust is.
Reinstall with new air springs and new lines are easy just in reverse order. One trick is to prime the system with some pressure to inflate the air spring that it clips in at the top and secured with the retaining plugs. I also tested the system for leaks with soapy water again to ensure no leak at the fittings.
While the car is off the ground, I also took the opportunity to top-up/reapply lanolin based fluid film in certain areas that normally difficult to access. The whole job took me 8 hours in total, but I was doing it at a really slow pace with plenty of coffee, biscuits and distraction by neighbour’s cat. The actual time spent on replacing air springs and pressure lines probably is three hours.
Finally, 10 hours after putting everything back, with the car parked on relatively level ground, locked and undisturbed, it was measured a total 2mm drop (over the 10 hours). According to w220.wiki site, the allowed drop is 2mm per hour. So it is fixed now.
Tools you need:
A good steady car jack, ideally low profile one as you need to jack with a wood under the differential. It is not safe just rely on single jack in the middle but to use jack stands.
A good steady car jack stands to keep you safe, always put the wheels under the car to provide redundancy in case of jack or stands fail.
A 17mm deep socket to remove your wheels. It will be handy to have an impact gun but this is not essential.
10mm spanner (thin spanner or difficult access socket with side opening if you have one)
Stanly blade to cut nylon pressure lines.
Hammer with some weight, you need this to knock the old air springs out.
Parts you need:
Well, this depends on the investigation and individual circumstances, as said, it could be anything or everything. In my case, I need two air springs, pressure lines and fittings.
For air springs I decided to go for Aerosus as their air springs for my make and model were on sales.
For pressure lines, the OD is 4mm and the ID is 2.5mm. You need Nylon pressure tubes (Polyamide in fancy terms) complaint with PA 11-PHL or PA 12-PHL for the connector and DIN 73378 or DIN 74324 as well as ISO 7628 standards. These are here to ensure the tubing is up for the job of pressurised air system, automotive environment as wells as its thermoplastic requirements.
The length for left is one meter and right is two meters, it makes little difference in price if so I bought four meters each total eight meters in case I messed it up. I decided to use blue for left and red for right. You can use the standard white ones but I prefer the coloured ones. My previous BMW F11 uses blue for left and red for right so I just carried on with this colour scheme.
For the fittings, I would recommend to use genuine VOSS Quick Connect System 203. Thread size is M8x1. (Mercedes doesn’t make them, they buy from VOSS, and so does their fuel return line nozzle. I think the return nozzle on the diesel injector is VOSS Quick Connect System 249LB but I could be wrong.) The VOSS fitting has three o-rings, two internally and one outside, there is also a grip ring with an opening.
The VOSS fittings are not designed to be reused again with fresh tubes. If new pressure line is needed then new fittings must be used together with new tube.
The torque setting for the fitting of M8 size is 5+1Nm. The length to push in the connector is 17+-1mm, you can mark the position with a permanent marker (as VOSS suggested) or I just used tape.
Finally, I hope this post can be helpful to someone.
Useful DIY summary. Thanks.
That should help anyone considering doing the job themselves.
Thank you do much for this thread, very useful👍
With regards to the lines, can they be purchased from mb dealership and also how do they connect ie join together?
Also does the system contain a resovour mounted near the subframe?
I think you can buy them directly from Mercedes. I decide to buy them from third party supplier (with the right specifications) and buy them in meters so I have some spares to mess with.
On the pressure lines I removed, there are parts numbers.
Left pressure line: A212 327 11 45
Right pressure line: A212 327 12 45
Mercedes also sells a repair kit containing some length (1 meter? Cannot remember now) of the Nylon tube with a brass joining fitting just like the one for repair brake pipes. However I do not like the idea of cutting and rejoining them with repair kit, because the whole length is manufactured at the same time, if one section has micro fracture due age and wear & tear then I'd expect other section to follow soon.
There is an instruction on VOSS website, here're some screenshots of their QC203 fitting.
As for the central reservoir tank, my model does not have it. I think, on 212 platform, only E500 and E63 have the tank as they are equipped with full Airmatic (or someone ticked the box of full Airmatic optional extra), the tank supplies both front and rear air springs, also the valve block is different as well. To replace the lines to the front will be more challenging as some section of the pressure line route through the interior of the car like the S class.
Thanks buddy, looks like they're push fit type connections. I'm due to replace my rear bags on my S211, seem to get a slow drop to the rear during a very cold winter month but not much during summer. Will check the lines too for microfractures on my s211👍 🙂
Great write up. On mine I also had a leak through the compressor so that’s worth checking as well. The lines on mine had some tiny holes where they had rubbed on the bodywork (Just in front of the compressor). Road debris also gets between the bodywork and airlines which causes more abrasion. Shame they’re not sheathed in something really.
Disclaimer:
Symptoms:
The story:
The investigation:
Tools you need:
Parts you need:
Great post….I have squeaky and creaky suspension on my car (same as yours)….and also the same intermittent problem of one or both rear suspension systems dropping overnight.
I have no technical capability so was going to head to the local Mercedes for and have them just replace all the suspension…but I am guessing that is going to be eye-wateringlu expensive).
Seeing as I can't find how to message folk (maybe my post count is too pish) - how many of the Voss 203s are required for doing both lines on a 2014 estate???
This nob has moved to the top of my to do list...
Ive just changed my S212's rear air springs and what a nightmare it was. Was it rearlly, really much of an inconvenience to have to sit there letting the airsprings reinflate when they had taken between 1 and 3 days to drop ? If I had known whay an absolute bugger this job could be Id have never started it.
All was good following the points in the instructions above, all except the bit that goes "To remove the air spring is easy if you know what to do". Its pleasing that has been some people's experience but it was far from mine.
How I chuckled at that as I struggled to get the bases of the aitbags extracted from the wishbones. It was as though the damn things had been permanently and deliberately bonded in place. If I hadnt known better I would have sworn they were made as a single part. Those airspring bases are made of a very dense and resilient plastic and when they dont budge they really defeat all reasonable attempts to make them budge.
Any pleasant thoughts I may have entertained about being able to test the old airbags for air leaks in a bucket of water out of interest went out of the window as i realised they were never going to come out in one piece. After a couple of hours of trying to lift and tap them out I tried jacking the base of the airbags free using a solid metal cylinder on a trolley jack through the hole in the bottom of the wishbone with the top of the wishbone braced with a sturdy bit of 2" x 2" to the shock mounting point. Still no use, it just lifted the car without shifting the air spring bases at all. I had to resort to a combination of an angle grinder to make several cuts in the plastic base, a drill, a wood chissel and lots of time to cut the plasic base away inside the dish of the wishbone. Heaven knows what type of plastic they use to make these things, it really put up a fight.
The good bit of course was when the old ones were finally out, as it took no time at all to clean up the wishbones, drop the new air springs in, attach the air hoses, refit the shock absorbers and then turn the key to watch the new airsprings expand. Im hoping that will have done the job but if it hasnt then at least other jobs such as changing the pipework will be a breeze by comparison.
I found the quickest and easiest way of deflating the air is to puncture the bag with a drill. Only took less than a minute. I punctured it by drilling several holes into the bags. I completed replacement on my S211 using Arnott springs making the job a lot more easier as it does away with the resovour. For me the job took less than an hour each side, although I would describe myself fairly competent. Took some photos of the new Arnott springs shown in the thread below
puncturing the bag was the stuff of seconds but how did you get on pulling the base out of the wishbone ? To put it in context Ive been working on cars for 45 years and was assisted by a pal who is a retired mechanic.
That was easy too, I just followed the instructions as shown in the video. When you undo a few suspension bolts such as the shock absorber bolt at the bottom and a few other suspension bits, the punctured bag comes out much easier. I did have a crow bar on hand to press down on the wishbone with one hand whilst i maneuvered the bag out.
They can be very tight where the shaped plastic bottom fits in the wishbone. I use an air chisel on them. Usually dispatches them in short order.
On the 212's we always replace the pipes to the bellows when we replace them
