E55 BBA
NOxSensor MB Part No: A0009058611.
Brand New and sealed.
Mercedes have a well documented problem with NOx sensors..check out any of the forums.
The factory are unable to supply this part, they are on world wide back order. If you could buy one it would cost £442 + vat.
I managed to find this sensor in Germany. It is not a genuine Mercedes Part but is made by Bugiad in Germany who I understand make OEM parts for Mercedes..
Do not confuse this item with the Chinese copies which are all over E Bay..this is an OEM quality part.
I’m advertising this part for what I paid for it..I can return it for a refund but before I do that I’ve advertised it here in the hope it may do someone a favour.
Please check out carefully that this is the correct part for your car..if you have your EML on and fault code P229F present chances are this is what you need but it’s dependent on model & engine.
I can tell you it’s correct for the GLE with the 2.1 engine.
I ended up not needing it (long story) but please check out that it’s correct for your car.
I can’t accept returns as once it’s unsealed I can’t return it.
Thanks for looking and good luck
