NSR Door Panel
davidbilyk
Keyworth, Nottinghamshire
S211 E320 CDi Sport
Hi all,
I am looking for a Near side rear door panel, facelift with the ruffled leather and walnut in mushroom, or the reccomendation of a good SMART repairer in the nottingham area?
Hi all,
Assuming the walnut and leather bit are ok, you can take them off and use any facelift doorpanel, you just need to cut out the upholstered part, and then insert your leather panel.
Phew, i'll have a look at that this weekend then!!
Thanks Nick
hi
i'm assuming you're talking about 124?
if so yes definatly leather is held in with clips. these are NLA from merc though so you may have to improvise.
bear in mind the MB-TEX and Leather cards are interchanable (if you cut out the TEX insert) and then you can fit the leather.
walnut screws in from behind so you can move over your existing wood.
however the cloth 124's have cloth on the lower section of the door card (where the ash tray is) so, although you could cut them out and fit the leather it wouldnt match the rest of your cards. unless you get the whole set and do it.
also if you need mushroom be careful not to end up with cream and/or visa versa.
