Press hangup ( red phone ) * 6 together when menu comes up select software update then the first item on the bottom menu it should then come up with you software version (all from memory so hope I got I all right )
Thanks,
Mine certainly has its original software install,
The guys at the place where my alarm was fitter yesterday said they could not update it, and I should take it to MB, they have a star system, But they did say they activated the rear camera at my request, but at the moment I can't test because I don't have a camera installed, presumed I would have some extra menu with it activated but there is nothing, maybe when the camera is installed.
Was just wondering if it would be possible to update the comand 2.5 on the bench would be nice to send it to Comand online and get them to update it without the 4 hour drive, I just hate driving long distances. and don't fancy giving it to MB and say do it without some form of cost idea.
everything works as it should I have no steering wheel controls just need the firmware updating so I can install the latest maps, what do you guys think
Me nether, just thought would get it activated whilst it was in there, when I went to pick it up they said that comand had been updated and the camera switch on and I thought great ,but when I check the firmware was still the same, so not sure they have activated the camera and I wasn't planing on installing it just yet, still deciding on which one to go with. But thought I had read that there was some kind of menu to switch it on or off once it had been activated.
I also read that they would not be able to communicate with the comand because it was a retro fit and presume they must have done that to activate the camera
Any more ideas on this guys
- Does the vehical have to be present to update the firmware
- should there be any additional menu's when the rear camera is activalted
2. The rear view camera as well as DAB and tv have been activated on my unit.
When I select the rear view camera option in the setting menu, all I get is a
blank screen with a message saying check vehicle surroundings.
I will try get some pics for you of my ntg2.5 unit.
1. As far as I know, yes the vehicle has to be present in order to have the
firmware updated. The other issue you may have is getting your ntg2.5 unit
to show up on STAR, as most sprinters were not fitted with a central gateway
module.
Jazz so was this done before the unit was fitted?
Yep Comand online are the best guys to deal with, they know what they are doing. If only I was more closer to them.
