I'm up early this morning with a W204 in bits as I am mid way through retrofitting an NTG4 command system. Ihave purchased the head and display as well as the retrofit kit with fan, loom etc.
Everything was going reasonably well until I came to try and find where I plug the Can bus cables in to. After much searching I think they must be behind the kick plate in the passenger foot-well? Advice please.
The other thing I am unsure of is the new cable for the display. Does it just replace the existing one? i.e. plug in to the display at the top and the loom at the bottom in the same way the old one does or does go straight to the command head?
The instructions are a little unclear for a first timer, so any advice from someone who has experience of doing this would be appreciated.
Lee.
Lee.
