OBD scanner U581 pics
lynall
Kent
The silver one.
Following pics scanner plugged into my car after short town run then left standing for 1/2 hour before i remembered to get the camera out.
U581 from e bay £60/70 plus cheapo 16pin to 38 pin adaptor £10.
Sys 1 and 2 using ho2s means engine and cats up to temp as now operating in closed loop ie o2 sensors controlling the fuel mixtues.
St and lt i think is fuel trim and is corrections applied by the ecu following info from the o2 sensors
Map manifold absolute pressure
More
Iat inlet air temperature
Maf mass air flow aka air flow meter
Tps throttle position sensor
Second air is the pump on the front of the v on 112 and 113 engine always says error for some reason.
Nearly there
O2s11 ox sens bank 1 at the front
O2s12 ox sens bank 1 at the back of the cat
O2s21/2 ditto
Last one honest:D
Last 4 pics are the o2 sensor readouts tried to get a couple of pics as the readings changed but not fast enough with the camera.
Im not saying its the best tester but its certainly cheap and has helped me several times.
Hope that helps someone, does more stuff, freeze frame which i beleive captures data as you drive or a fault occurs, never tried it though.
Meant to say works on my car with the 38pin socket
Lisas W203 with std obd socket
Friends Bora x plate obd socket
Father in laws coras 1.2
Plus a few others.
Lynall
