Odd. Our A150 (new shape W169) has just developed an intermittent noise.
Sounds a bit like a pump groaning, or something. It does not change with rpm, nor braking, nor with speed, it occurs when moving and at rest. Once it occurs, it will continue until the ignition is turned off. If the car is then re-started, it will be some minutes before the noise returns.
It's quite intermittent; won't happen at all on some journeys; on others it starts within a mile of home, and then the only thing that will stop it is ignition off.
It's quite loud, and doesn't seem to get louder when the window is opened, suggesting it's occurring near the passenger compartment. It's not family members complaining about my driving, either
Being neither rpm nor speed related, and the fact that it continues even when the car is brought to a halt, without changing pitch on any of these actions, seems to rule out almost everything
My last guess is perhaps power steering pump, although turning the steering wheel has no effect on the noise.
Any suggestions or advice very gratefully received.
[apols to mods: this may be in the wrong forum, but it's not obviously right for the others, either]
