MangoMan
- Aug 10, 2005
- Location
- Hampshire South Coast.
- 2001 W208 CLK320 Coupe Almandine-Black. (Looks Purple-ish).
Hi chaps....
Just a quick one please.
My 2000 S500 (W220) has a random misfire.
A bit of background:
When I bought the car it had been more or less sitting idle for about 3 months.
Took it for quite a lengthy test drive before I bought and all was ok.
Anyway, got it home and after a couple of days, (waiting for Insurance and VED to clear) I decided to take it to the local Tesco Handwash, (used them before and they do a good job) then proceeded to put in some fuel as it was pretty much empty, and proceeded to go up to my local Sainsburys as they have a good Tyre Pump/Gauge.
It is about a mile up the motorway so gave it a bit of welly - nothing severe or high-revving - but when I stopped at the lights at the end of the offramp I noticed it was like lurching forward, as if I was releasing and applying the brakes all the time.
When I pulled away there was a definite misfire - could feel it! I thought, "very strange - never done that before"?
Anyway, parked up at the Air, switched off and checked my tyres - which weren't too bad really.
Got in and expecting it still to misfire - nothing! As sweet as a nut.... And has been ever since until today. (It has been about 13 days since I did the tyres by the way - behaved all that time).
Today it kept coming and going, usually going once switched off and then on again. Very strange.
So got home and I got one of those cheap Bluetooth OBDII Readers and did a Fault-Check.
It came back with a host of Codes, stupidly I did not take a note of them as I thought I had better clear them as they might be old Fault Codes in the ECU. Cleared the Codes and ran it again - NOTHING! No Codes at all....??? And no misfire.
Took it for a spin doing everything to try to bring the misfire back, (flooring it, kicking down, you name it) - nothing. Got home ran it for Codes again - Clear!
How can it misfire on one day then nothing for nearly 2 weeks then do it again...???
I'm lost here.... But I hear the MAF can cause this
Any ideas?
ps. By the way when I say misfire it feels like there are numerous pistons not firing, not just one.
Thanks in advance.
ps. Next time it happens I will remember to record the Codes.... Yes I know, stupid of me! No-one is more pissed off than me!
Any ideas?
Thanks in advance.
