James1976
- Jul 18, 2010
- Location
- Borough, London
- 94 300 SL-24 in Bornite, 2010 Smart Fortwo Passion
Evening all.
This is going to be a bit hard to explain but I'll try my best!
Seemingly the front right hand side suspension on my 94 R129 SL is making an odd noise. It's most noticeable when I'm manouvering the car out of my space and it's on polished concrete. Less so when on the move and you don't notice it at normal driving speeds.
It's kind of a clonking noise when the wheel's being turned - it clonks without any specific patterns every now and again the more the wheel's being turned, as if the changing of the gemoetry at the front (as the wheel geometry moves over) makes the springs move, or a ball joint click and this goes through to the body and is also felt at the steering wheel?
The bushes all seem fine from a visual inspection and both a non Merc and a Merc specialist have looked at it (albeit without a detailed explanation) and said they can't see anything on a general check over.
Do they all do this? Could it be the steering box, and if so do these have oil and therefore could it have leaked out? Asking as trying to avoid many hours labour charges
Any suggestions no matter how rude or obvious gratefully received!
